this is the first time i have ever had to work on a TnT. had this motor shipped in, i know where everything goes. but how do i fill the system?? i haven't a clue, no manuals with this type of pump.
This is different than the ones I've torn apart and rebuilt, but I used the same fitting and pump that is used to fill the lower unit. It is the same thread. When filling, you will need to take it out durning filling to relieve the air pressure build up.
I doubt that thing fills to the top.
got it done, what a pita, ended up using a 1/4 siphon hose, would siphon the fluid out of the bottle, then shove the hose into the pump. now runs like a dream. now to the the linc n sinc correct.
