trendsetter240
- Jun 22, 2009
- 1,458
Last night I removed the manual trim bracket and installed a power trim bracket on my 1995 evinrude eleo 70hp. The trim bracket came of a 1990 evinrude 70hp.
I removed the trim relay assembly from the old motor and hooked it up to my new motor.
When I tested the trim and tilt it seems to work fine except that when I tilt it all the way up and then try to tilt down it just hangs there. If I keep the down button on the engine will eventually tilt back down after the bottom tilt pistons have fully retracted.
Is this by design? Please take a look at this short video and give me your impression of this tilt unit.
Thank you.
Thank you.
