Started wiring up my trim today and got most working. Here is what I go so far.
LIGHT BLUE / WHITE STRIPE = Trim UP Switch put this to the trim up relay
LIGHT GREEN / WHITE STRIPE = Trim DOWN Switch put this to the trim
BROWN/WHITE STRIPE = Trim Sender to Trim Gage put this to the Gage located on the motor near the trim pump.
All this is easy so far now here is my big ?
PURPLE / WHITE STRIPE + Trim "Trailer" Switch !!!! What the heck is this? I have the wire for it but don't no what a Trailer Switch is or where it is located on the motor. My trim down works fine on the control but the trim up don't work at all.
I'm a bit dumb so if you can please explain this in detail. I don't know what the parts are called on the motor.
It is a 3 wire system coming off the trim motor all of them are hooked up. If I put power from the battery to trim up works fine same with trim down. I just need to hook up the purple wire.
On my control I only have a up and down button but there are 4 wires as I stated coming off the controller for the trim.
Enough said on this part. This is what I tried so far.
I tried to hook the purple wire to the trim up Solenoid it will only work the trim and wont go all the way up for trailer so I know it cant go there.
