tropical fishtank help
crazy charlie
We got my dad a fishtank to keep him busy.The fish are doing pretty well.Mollys,sissortails,swordfish and a couple of algae eaters.He runs the filter 24/7 and the water is getting a little cloudy.any suggestions on getting the water crystal clear??? Charlie
JustMrWill
Master Chief Petty Officer
Re: tropical fishtank help
How long has it been running?
My daughters tank was getting real cloudy. We added some water clarifier and algea killer then changed the filter and it was sparking clear within a day. It is only a 10 gal tank..so may take longer on bigger tanks.
How big of a tank? How many fish? Is it near a window/gets direct sunlight?
-JMW
(I am not IN ANY WAY a fish/tank expect. Check with the local pet store for their opinion if there is any doubt).
Bob_VT
I have heard that over fedding will cloud the water.
Aquaman
How big and how long has it been set up? Sounds like an algae bloom, should clear in 1-3 days.
crazy charlie
The tank is a 20 or 30 gallon which he has had up and running for about 6 months now.There are about 14 fish including 2 algea eaters.The box that it came in said it was a size 29 kit if that means anything.No direct sunlight coming in .I guess I will check the petshop for water additives.
mattttt25
charlie- i've been running a 75 gallon tank successfully for about 6 years now. first, the larger the tank, the easier it is to keep. lots of reason, but just accept the logic. not that it helps your dad. it usually takes 2-3 months for the tank to develop the right ecosystem, but your dad may not be there just yet. but once there, it's pretty easy to keep it clean. in fact, i rarely clean my tank and the water is always clear. some suggestions...
1. make sure he has a simple water kit and uses it. you need to have the proper ph levels and depending on the water you add, that could be a bit difficult. he may need to add ph up or down to get it right.
2. water changes- should be done every 2-3 weeks until things get right. he simply removes 20-30% of the water in the tank and replenishes. experts suggestion you keep that up, but from experience, once you get the tank running well, you can let it slide a bit.
3. light- too much, too little, both can hurt. usually done by trial and error. algae fish are nice to look at, but they actually don't do much to clean the water, except for the sides. i currently have my light come on at approx 4 and turns off at 12, giving them 8 hours of light. but your dad's tank could need a little more or little less. if he's having algae problems, i'd cut the amount of light down a bit.
4. filter- you mention he runs it 24/7 and there is no alternative- all tanks must have constant filtration. some kits come with crap filters, so he may want to look at upgrading. at the minimum, it needs a particulate filter (sponge) and charcoal filter.
5. plants- i have had good success with live plants and my tank looks great with all the vegatation. i don't know if it's true, but i've found that the plants seem to help complete the ecosystem and keep the water clean and fresh.
good luck and any questions, let me know.
crazy charlie
Thanks Matt.IO guess the water kit is the first thing I should get him.If that does not do the trick,I will change out some of the water.Do you have to let the new water sit over night before you add it to the tank??
mattttt25
charlie- water kit is a good first step, just go with a simple cheap one.
water changes is a must and i'd do one right away and then again every 2 weeks until the water clears up. again, only remove about 25% of the water. Water doesn't have to sit overnight. if it's city water, you want to buy some chemicals that dechlorinate the water before adding it to the tank. again, cheap and available. you simply add a drop to each gallon you add (follow directions).
eurolarva
The water changes should be done with a water cleaning siphon. You want to get as much crap out of the gravel as possible however you do not want to remove more then 20 percent of the water while doing this. Water added should be tested for chlorine. Make sure there is none. Usually two or three drops of chlorine killer will do 1 gallon of water. Also water to be added should be within 2 degrees of the water in the tank. A couple of degree shift in water temps can shock the fish. I would also get a cheap light timer for the tank so the morning and evening light cycle stays the same.
crazy charlie
Thanks again guys.Sounds like I have the right info.My dad has not lost a single fish yet so he thinks the cloudy water is fine.You can guess what is going to happen from here.I will get his water clear and the first fish that dies is going to be my fault..GUARANTEED!!!! Im sure you can all relate to the "blame game" Charlie
