ForceEightyFive
- Jun 1, 2011
- 20
Well after taking care of my spark problem a while back I took my 89 Force 85 HP out to the lake today. I also changed the water pump. Fires right up on the trailer and the dock although idles a bit rough. I also took the carbs apart to clean out and have cabs set at 1 and a quarter turn out. Anyway when I when I tried to reverse out of the dock the prop was barely turning in reverse even with the throttle turned all the way. When I put it all the ways forwards the prop barely turned as well. Did I screw up the shift linkage "setting" or does it sound like a carb problem? Fuel recirculation? When I put the boat back on the trailer ALOT of unburned fuel leaked down from the weep holes. Any help would be appreciated. Thanks.
