jmillerfla
- Oct 7, 2010
- 5
I have an I/O with two batteries. When battery switch is on #1 engine won't turn over, almost like a dead battery sound. When on #2 the same thing happens. When battery switch is put to all, the engine turns over like normal. Batteries are newer and fully charged. Changed battery switch and the same result. Need help to figure out where a problem may be. Any suggestions? Ignition switch, loose wire?
