My "TKS" circuit is not working properly in that after the engine is warm, the fuel enrichment port remains open. I got the schematics (thanks to this forum!) and found only 4 components in the circuit - a 20 A fuse, diode assy, TKS module, and temp sensor. The fuse was blown and blows immediately when replaced. I ohmed out the coil on the TKS module and it checked within specs @ 43 ohms. Temp sensor checks in that it reads below 1 ohm when the engine is warm. The diode reads open in one direction and somewhere between 900 - 1100 ohms in the other. My question is - shouldn't the diode read less than 1 ohm in the "forward biased" direction and if so, is this diode my issue? Any help would be greatly appreciated. Just trying to avoid unnecessary parts swapping.
