HotTommy
- Mar 15, 2013
- 1,025
Jiggz, here are my assumptions and conclusions.
1. Each cylinder must get spark at the right time and that time is determined by the position of the trigger assembly. I'll call the part that sends the signal to the #1 cylinder Trigger 1.
2. Regardless of how the rest of the ignition system is wired, Trigger 1 must be used to initiate the spark to cylinder 1. Otherwise it will not fire at the correct time.
3. My wiring swap allowed the signal from Trigger 1 to go through the portion of the switch box and coil pack for cylinder 5 before being routed back to cylinder 1. All this did was test the portion of the switch box and coil pack normally used for cylinder 5.
4. As swapping 1-5 and 2-4 showed no change (i.e., cylinders 4 and 5 were not firing properly after the swap), I concluded the problem must be either the part of the trigger assembly that fires 4 & 5, or the carburetor serving 4 & 5.
5. As spraying a fuel-oil mix into the bottom carburetor had no effect, I conclude the carburetor is not the source of the problem, so the part of the trigger that fires 4 & 5 is faulty.
