Troubleshooting ignition coil 5.0 Mercruiser
I can do that and also I’ll make sure the soft fuel line isn’t collapsed
should not be any soft fuel line. there is the A1-15 fuel line from the tank to the filter and steel lines from the filter to the carb.
you cant crush A1-15 without a vice.
WrenchNhammer
So if my boat has a soft rubber fuel line where is the anti-siphon located. Taking a remote fuel tank with me
the anti siphon valve is the connection nipple on the top of the pickup tube.
WrenchNhammer
Once I pulled the fuel line off I noticed something inside it and pulled this out. The guy at ORieleys said it looks like a fuel line inside a fuel line
WrenchNhammer
Saw what looked like water in carb so I took the separator out emptied it and refilled with good fuel. No problem however it did overheat. I was revving it up a bit do you think that the muffs aren’t meant to be used in this matter? It has a new impeller and thermostat
the water separating filter is a one-time use. you cant simply empty and replace.
that does not look like the proper A1-15 fuel line. and no, ORieleys would not have USCG approved fuel line.
WrenchNhammer
It’s running good right now but overheated. Not getting a good seal on muffs. Gonna put it in the lake and try it out
if your hose in on and you have good flow (getting a 10 foot spray from the muffs) it shouldnt overheat
WrenchNhammer
I wouldn’t say 10’ spray but definitely getting a bit less. I’m losing quite a bit of water around the seal on muffs. Seems like they used to fit tighter…
