BuzzStPoint
- May 27, 2009
- 1,003
Re: Truck transmission gone bad.
Exactly. For most transmissions.
Exaplme my impala. No over drive. A master kit, with the 4th gear clutch hub and solenoids I can buy for about 300 bucks. I would charge minimum 800-900 bucks to do the job.
Also it doesn't take a Master Mech to know how to rebuild a transmission. It just takes the understanding on how the auto trans works. Many people will look at a trans and say forget it.. Then look at a break down and see 50-100 parts and say no freakin way..
Sure it's more then spark plugs and oil changes...
I knew a guy that could pull a 350 out, rebuild and put back into a car or truck in no time at all. But, when asking him to rebuild the transmission, he wouldn't touch it. Not even think about it.
For some back yard mechs, sometimes the extra 300 bucks for a used or rebuilt trans it better and easier then rebuilding it. Me? I would rather rebuild it myself and save the money.
On a side note to rebuilding your self. While on a difficulty level of 6-8 out of 10 (depending on trans, FWD are a bit harder because of space.) it's not for everybody. If you do want to build yourself, Buy a master kit, and a ATSG book for the trans. It's quite fun if you like kind of thing.
If the body of your truck is still good, rebuilding the transmission is the way to go. Although it has 150K miles, the 4.3 is a very good engine and will last if properly maintained.
Unfortunately, people don't understand automatic transmissions, and they don't properly maintain them--changing filters and fluids, etc. Heat is the biggest reason for failures in automatic transmissions. You would expect the oil and filter to be dirty in a truck with so many miles.
My recently departed son in law was a Master Mechanic, and he loved to rebuild 2 wheel drive Chevy truck transmissions. He could remove a 2wd Chevy transmission, tear it down, clean it, replace the bands, reassemble the transmission and reinstall it in about 75 minutes. He charged $1100 for the job--and seldom put more than $125 in parts into the job. Transmissions are often a license to steal for a repair shop. Shops are charging even more for repairing electronic transmissions, when they're actually less expensive to repair.
Good luck with your repairs.
