bradford0113
- Mar 10, 2010
- 19
I am trying to diagnose the miss that can be seen / heard in the following video.
The miss only happens at low idle speed; when throttled up, I no longer notice it. Here's the situation... First out, wouldn't idle at all. Removed and cleaned carb which appeared gummed up, then seemed to idle well running in bucket. Compression check top = 65, bottom = 55. Decided to do a decarb before going back out on the lake. Completed decarb process and now this miss shows up at low idle. New compression top = 50, bottom = 50. Appears to have good consistent spark. Could a compression issue be causing this?
Any ideas?
Thanks
~Brad
Any ideas?
Thanks
~Brad
