Type of rivets used to secure floor to ribs ??
mr 88
I have searched the forums and think it will be easier just to ask this[ I am sure ] played out question. Replacing floor and wondering what size and type of rivets to go with. Do I try and use the old holes in the ribs and go with maybe 1/4" rivets or drill new ones and go with a smaller size rivets.I have read where some people just use SS screws and also wonder if they loosen over time ? Pros and cons to either method ? I have a HD Rivet gun that goes up to 1/4"" for what it's worth,thanks.........
barato2
Re: Type of rivets used to secure floor to ribs ??
hard part on reusing factory holes is drilling the holes in the new floor to line up perfectly. i think most people just drill new ones and use 3/16 rivets. i got 3 boxes (25 in each) of large head 3/16 rivets with grip range up to 1" from McMaster-Carr for abt $25-30 shipped.
at least a few folks have done screws, incl our esteemed moderator, and have been happy. i think if you slather em in 5200, they probably can be kept from backing out.
mr 88
Thanks,are they aluminum rivets or some other material ? May start this weekend so will have to buy local.
barato2
yeah, i'd use aluminum. no galvanic corrosion issues and you'd need that HD rivet gun to pull 3/16 SS rivets. good luck finding em locally in long enough grip range if your floors are any thicker than 1/2". i bet McMC could express em to you by this weekend. or you could go the screws route since those are readily available in correct lengths....just use flatheads and countersink em
North Beach
MR88, my deck was 1/2" plywood and I used 3/16 aluminum rivets with 1/2" to 5/8" grip range. I purchased all of the rivets for my restore at rivetsinstock.com
mr 88
Using 3/4 decking . Store close by called Fastenall that may have rivets with 3/4 plus grip range. If not I probably will goes SS route with 5200,thanks guys.
