speterson1011
- Aug 30, 2010
- 65
I will start with some history of the engine. 2000 Johnson 2 stroke 4 cyl 90HP. Recently rebuilt powerhead have had no problems. I'm at 60 hours on the new rebuilt one and it was broken in properly. I hardly ever run it wide open. When I do it will run wide open for about 2 minutes then start to shudder like it has an insane misfire and throw a hot alarm. I disconnected the oil reservoir and mix it by hand since the rebuild. I am 100% it has the right amount of oil. The disconnect was definitely done properly as well. Has an impeller that has maybe 10 hours on it along with the whole housing and water pump assembly. It is peeing perfect out the back. Spark plugs looked clean not burnt, or gummed up. The thermostats are newer along with the springs and I boiled them in a pot of water and they opened up. I know. I should check compression right. I think I am just scared to since its such a newer rebuild but it has been over a year and is no longer warranted. Is there anything else I am missing? When it does start to shudder and throw the hot alarm I can bring it from 4xxx rpms down to 25xx rpms and it will stop it within seconds and then I can get back up to 28xx rpms but any higher it will throw the hot alarm and shudder. Any other ideas? Thanks everyone
