wildmaninal
- Jul 14, 2007
- 1,897
When I got this motor the drive shaft was stuck in the bottom of the power head and the foot was off of it. Obviously the previous owner either didn't put the o'ring on the top of the drive shaft or never had it apart to replace it. Well that drive shaft is stuck in there good none the less. I know the motor runs, I had it running a few days ago with the water hose hooked to the pipe.
The only thing I would like to know is how do I get to the bottom of the powerhead?
I started to take the lower unit cover apart to see if I can split it, I figured I might be going in the wrong direction and that I need to check with you guys here first. This is going to be a keeper for me when I get it fixed. Although I scuffed up the drive shaft a little while trying to clamp on to it, don't know if it would be wise to use the motor like that or not.
I've been knocking these motors out one by one taking care of each problem that I find and thanks to the guys that have helped me on my other threads. Been lucky that I haven't had to spend any money on them or not much money if I had. I got my little 5.5hp wards outboard running today that I only paid $5 for.
