My Alpha One, SN A670521, was pulled to look at the gimbal. Now I have found that the upper unit will not turn in either direction. It worked fine last year, except for the roaring when the engine was running, which I suspected was the gimbal bearing. I split the lower from the upper and put the upper in a vise and took a 14" pry bar to it, in the drive shaft yoke. It doesn't want to move at all, in either direction. I do not have a 12 point 3/8 socket on hand to pull the top cap off, but I'm going to try to get one of those tomorrow.
Is there anything I could be missing here, before I tear into this thing?
Thanks,
Chris
Thanks,
Chris
