dropbear68
- Jan 21, 2013
- 199
Im taking my boat out this coming weekend, well if I can get the old tart to go I will, she wont start, its highly possible I have flooded the carbs out, the primer bulb on my tank doesnty go hard when the carbs are full so I just kept on squeezing thinking there was a problem with the fuel hose, so i pulled the hose of the filter and pumped and its pouring fuel out, I pulled the plugs and they were wet and oily, I ran the batt flat trying to start it using plenty of choke and nothing, I tested the spark at the leads and theres no problem there plenty spark, so Ive cleaned the plugs up and have the batt on the charger, Ive left the plugs out so the fuel can evaporate over night, does flooding cause this no starting biz? Ive owned lots of old Chrys and never had one that wouldnt kick easily, now Im pannicking as I dont want to leave it home Im busting to get her out, can someone give me some advice on where to look next, also the factory starting procedure if anyone has it, my procedure with Chrys has always been prime till bulb goes hard, pull the throttle lock out open the throttle, push and turn key and usually they fart into life ok
