Fishermark
- Oct 19, 2003
- 5,622
Re: URGENT: water in engine bay
I know your engine is an OMC, not Mercruiser, but to give you an idea of what Mercruiser recommends: (And oil formulations AND recommendations change over the years.... so there really is no use trying to figure out what OMC would have recommended for your engine when new)
This is from Mercruiser:
(And forget the idea that one brand is better than another... the important thing is the certification - not the brand).
To help obtain optimum engine performance and to provide maximum protection, we strongly recommend the use of the following oils listed in the order of recommendation:
1. MerCruiser / Quicksilver Synthetic Blend, NMMA FC-W rated, 4 cycle oil.
2. MerCruiser / Quicksilver 25W40 NMMA FC-W rated oil.
3. A NMMA FC-W rated oil.
4. MerCruiser / Quicksilver 4-cycle 25W40, non FC-W rated oil.
5. A good grade straight weight detergent automotive oil per the operating chart below.
NOTE: The use of non-detergent oils, multi-viscosity oils (other than as specified), non-FC-W rated synthetic oils, low quality oils or oils that contain solid additives are specifically not recommended.
