four winns 214
- Oct 25, 2008
- 778
Re: Used Chaparrals - Vp or Mercruiser a Deal Breaker?
Here's my perspective as an owner of both an Alpha 1 and a V-P Duoprop.
The Alpha 1 (actually, it is an MR-1 which is functionally the same as an Alpha 1) in my Sea Ray cuddy is more than 25 years old. I have owned it for seven years and it has taken me on 1,500+ miles cruising the Ohio, Cumberland, and Monogahela Rivers. I have paid to have the impeller changed three times and have also paid to have the bellows changed and alignment checked. Those are jobs I would rather leave to an experienced hand. I change drive oil and anodes myself. Other than that, that tough old bird just keeps churning the prop.
The V-P Duoprop on my Four Winns deckboat is a very nice drive. It shifts without the characteristic gear "crunch" of the Alpha and there is no left turning tendencies with the counter rotating props. I have the alignment checked by a pro, but change drive oil and impeller myself. The impeller is mounted on the front of the engine and an ape could be trained to change it. It's that simple.
I have had no major problems with either drive. If two boats were equal in all ways but the drive, I would choose the V-P. However, one issue to be considered: If professional work is needed, just about any body of water big enough to support an I/O powered boat has a Merc authorized shop stocked with parts on it or near by. Not so with V-P.
