Used OMC parts supplier
boydog40
looking for part number 172838 which is the hydraulic hose for the old style "external" PTT pump. dealer wants $300 for it, cannot be made up locally either, ebay doesn't have one nor does craigslist.
any hydraulic shop should be able to make a line.
boydog40
we have several hydraulic hose shops in our area, none were able to help
clemsonfor
I now see ebay was tried.
Next thing would be to buy a used motor with the parts that would work, get what you need and part out the rest or keep it for your motor for spare parts
thegipper
I've found a bunch of stuff on ebay recently.
A new old stock drive shaft bearing housing which is normally $186 for $26 shipped. A new impeller housing (new old stock) that is normally like $80, for $13 shipped.
Never mind, just saw that you tried ebay.
Will Bark
Have you tried the NAPA store that is downtown? They have made hoses before don't know if they still do
boydog40
will I went to Hburg hydraulics said no one will have that type fitting that this hose has. found a used 85 I can get for 250.00 probably do that and part out the rest.
thanks guys
GA_Boater
A decent hydraulic repair ship will keep the fittings and replace the hose, which is what goes bad. Very, very rare for a fitting to go bad.
