Re: using tachometer for carb adjustment
hello<br /> there is one thing yammis are great about.<br /> its carb adjustments<br /> if the motor is all set up and has no mechanical problems all you have to do is set the air/fuel screws to the proper turns out from lightly seated and it will run correctly.<br /> set the idle speed about 750 or so on the flusher and it will work ok<br /> good luck and keep posting
