The timing is fixed at the factory------It does not change over the life of the motor.-----Unless of course if somebody messed with it.----Sheared flywheel key changes the timing.-----So if you take motor apart / reassemble the timing does not change.------What is the model # of your motor ?-----Running issues?----Why the question ?
