That’s what I was thinking I just haven’t ever changed one. I see a Allen head in the center of the pulley. Is that where you go about changing it? Thank sUnless the V belt is loose. In most cases your power steering pump belt needs replacing
It’s not loose it’s wore outUnless the V belt is loose. In most cases your power steering pump belt needs replacing
No.I see a Allen head in the center of the pulley. Is that where you go about changing it?
