homelite
- Aug 13, 2002
- 159
Hello. I am new to v drives, but am a mechanic. I am trying to remove my prop shafts on my 1999 310 Sea Ray Sundancer. It has the Velvet 5000 transmissions.
I have the cotter pin and large nut off the end of the shaft (at the transmission). I removed the 4 bolts securing the coupler to the trans output flange. Now the question, how to get it apart? Chisel and hammer? Heat with torch?
I need some advice from someone that has performed this as I don?t want to damage anything. I want to continue Saturday so if you can help answer the question, please help!
Thanks in advance
Scott in PA
Thanks in advance
Scott in PA
