1995 Johnson 140 HP. I changed the timer-base and power-pack with new CDI parts. (Motor was surging at highspeed)
I found orange and orange black wires on stator cracked and shorted together when I remove the stator. Anyway. I repaired that too.
I timed WOT as per Joe Reeves method. I set the WOT timing 14 degrees BTDC. The manual says 18degrees. It starts right up but backfires loudly through the exhaust at idle. Above 1500 RPM, backfire goes away. This makes me think the idle timing is off. My Reeves guide says the idle timing will take care of it's self. The ears on the CDI timer base are a different than the ones on the OEM base, so I'm sure the timing is off. I'm not sure what to do now. I looked at the service manual. It says I need a test prop etc. to get idle timing correct. Help please.
