I am in the process of rebuilding a 1988 225 HP powerhead. I had mentioned to Faztbullet that the bottom crankcase head bolts were severely corrode, and he recommended that I upgrade to the bolts used in the 2001 engines. (I'm talking about the bolts for the upper and lower crankshaft bearing carrier assemblies not the cylinder heads.) They are equivalent to a grade 7 and are stainless steel (I think). I thought that was a good idea, until I looked at the price from Evinrude. $10.96 each times 16 bolts.
I could not find any grade rating for stainless steel bolts, but I did find listings saying they were equivalent to or exceeded grade #.
I checked McMaster Carr and found these.
Extreme-Strength 12 Point Flange-Head -Stainless Steel
1/4-20 x 3/4" , 96242A506 $2.00 each
1/4-20 x 1" , 96242A509 $2.18 each
They are stronger than a grade 8 bolt, and much more affordable
Up to 1" long they are Type 304 stainless and over 1" long they are Type 450.
http://www.mcmaster.com/#standard-cap-screws/=lgiasc
I have not purchased these yet, but I don't see why they wouldn't be a suitable alternative. Just passing this along for anyone rebuilding a powerhead looking to save a few $$$. They are about the same price as the OEM grade 5 steel bolts that will rust. and $9.00 less per bolt than the OEM upgrade stainless steel bolts used on 2001 and newer.
Update: 2/14/13 I received the bolts today. They are manufactured by ARP, a company recognized for high quality fasteners. I did some reading on the ARP site. They use a proprietary process involving power dumping to strengthen the bolts. 304 stainless cannot be heat treated so this other process is used to strengthen the bolts. The twelve point head is the same as the rod bolts so you won't need a special socket.
Excerpt from ARP catalog:
"17. Define “Power Dump.”
This is a term used to define the heavy extrusion of the fastener body during forging. The part is forced into a die much smaller than the blank thereby causing a severe reduction in cross section area. This reduction of the cross sectional area is accompanied by an increase in length because metals can’t be compressed. However, power dumping or reduction, delivers a significant increase in strength properties and is part of the patented process we use to produce fasteners from 304 stainless steel with 170,000 psi UTS........."
