Re: Vacuum at WOT
off topic but I gotta say it specking of constant volume fuels.<br /> I was about 18 when down in south texas a 36 inch natural gas line rupthred and burst into flames. was quite amazing with natural gas under pressure shooting flames several hundred feet into the air. we all thought well just close the valve, wrong.<br /> Red Adairs team came in and detonated a charge that extinguished the flames, then they cut off the pipe. then some crazy engineer calculated the volume of gas flowing and told the welder how fast he had to weld the cap on in inches per minute so the mix would stay rich enough then go lean enough not to reflash. we watched the weld job on the TV feed to our work center. two welders and a fitter but no engineer but it worked.<br /> now you tell me who would be crazy enough to weld a plate on a gas pipe that big spewing thousands of cubic feet per hour of natuaral gas?<br /><br /> but it worked, the welder never created enough flame to light a smoke.
