vacuum line
jkeating
Re: vacuum line
so start it warm it up. turn it off, connect pos/neg leads to battery and clip onto no.1 spark plug. fire it back up. every time the no.1 plug fires, the light comes on. you look through the run and watch to see the number of degrees is passing tdc?
Say I see its at 10 degrees, the motor cover says 8 degrees btdc so I loosen the nut under the dist. (still running?) and turn the whole thing slightly clock wise
achris
More fish than mountain goat
Re: vacuum line
I usually put the light on the battery and the plug lead before I start it for warm up... I know I'm checking timing, so set the gear up 'off the bat'.... You can do it either way, makes no difference...
I prefer to turn it off when loosening the bolt. ;) Looks really bad when you get your hand caught in 'rotating machinery'... :eek:
As for the direction to turn the dissy? I have never bothered to take notice. I just start turning it a little one way, and if the marks move the wrong way, turn the dissy the other way.... Once you have the timing right, shut it off, tighten the bolt, then restart and check the dissy hasn't moved any while you were tightening it down....
But in essence, you got it....
EDIT: Just looked at the manual... You're right, CW will retard the timing....BTW, you got a manual?
jkeating
Re: vacuum line
Thanks so much man,
Wish you were around here :rolleyes: Id just pay you lol
Sure sounds like you know what your doing
Looks like ill give her a shot tomorrow and I guess ill go from there.... I hope the time is just off and once I change it ill be done.... Usually don't work like that round here :blue:
achris
Re: vacuum line
Thanks so much man,
Quite happy to do it for free. Just pay my airfare. :laugh:
And yeah, I've done it before... a few times :facepalm:
Found this in the manual for you...
attachment.php
