Valid Serial Number ? 4.3 GL
penske
1998 Volvo Penta 4.3 gl Model # 432BPBYC Drive Unit #3868720 Transom #3868413 in a 1998 Four Winns RS 208 hours on the motor Serial # of motor T01306611
How can I validate this serial number. I can't get it to come up in the Volvo Penta database or is there something else I should be using to look it up? T01306611. It was hard to read under the cover but I think this is what I read.
Thanks
Lake Norman Boater in NC
jerryjerry05
Re: Valid Serial Number ? 4.3 GL
Not sure if Four Winns is still in business.
Send them the hull# and ask for the info on the motor/drive.
Fun Times
Hi there, This engine model number (432BPBYC) would be found under the OMC look up table. You would not find the serial number under the Volvo website. The change over happened when Volvo basically bought out OMC back in the mid 90's. PS, the T in the T01306611 indicated to me that it's an OMC serial number. Hope this helps, Good luck.:)
Here is your parts catalog for you, 1998 OMC 432BPBYC hp L Stern Drive Parts
