Venturing into performance upgrades for an AQ271C
Re: Venturing into performance upgrades for an AQ271C
Humpty Dumpty is going back together slowly
here are a few shots. spraying the flywheel and coupler, and the overall shot of today. need to grab the battery and hot-wire the coil, ad some fuel and fire it up
IMG00411_zpskmxo2hm4.jpg IMG00414_zpsgznodv8l.jpg IMG00412_zpsroahl72x.jpg IMG00410_zpsxh0onidl.jpg IMG00413_zps1u0d8kmd.jpg
captmello
Sounds great!
Would you mind recapping what you did to the motor? And, what HP gain do you think you've gotten.
kept the short block in tact. I updated to vortec heads, switched to a vortec marine intake (factory Volvo Penta part). I added a carb spacer for low end torque. Added the Comp Cams 262/268 cam and roller rockers. added a Melling high volume oil pump.
Engine went from compression remains at 9.4:1 since the heads are still 64cc, however with the swirl chambers. Talking to the local engine shop, its estimated we bumped from 275hp stock to about 330-340 range.
Tail_Gunner
Engine went from 9.4:1 to about 10.3. Talking to the local engine shop, its estimated we bumped from 275hp stock to about 330-340 range.
:cool:
just a few more pieces to bolt back into the boat and the engine goes back in.
mybadford
I like your set up and it sounds good too. Do you run thru hull exhaust?
Do marine engines not have high volume oil pumps in them? My AQ231A holds 80psi cold and 70psi warmed up at an idle. It buries the gauge anything beyond that. I thought the gauge might have been messed up but I put a mechanical gauge on it just to verify.
no, the stock marine motor oil pump is the same as a stock truck motor.
I will eventually be running a thru-hull
Motor in, outdrive on.......its raining.........tach doesnt work......:( troubleshooting in the rain is a pain in the backside.
mybadford
I was just looking for this thread wondering if you had the engine in.
who ever designed the trapezoidal connector on VP wiring harnesses should be forced to listen to its a small world
after a few trips out, now time for carb tuning.
looks like I can go just a bit richer on the jets.
Ok, its been about 15 months since I have put the boat back together. I think I need more power. It goes plenty fast, and burns plenty fuel, however I think it could go faster.
Walt T
I built a 383 stroker motor for my 22' Cuddy with 290 DP, boy oh boy its like a big block in there. On plane time and top speed all improved. Went up a pitch, its pretty sweet. I used flat top pistons with the stroker kit and its at 9.71 compression now with standard 76cc heads. This winter a set of Vortec 64cc heads will go on and intake of course with a cam change. I'll stay with the standard Holley 625 cfm I suppose. The change to Vortec should get me to 10.5 compression, but the math will tell. I read your thread with interest, seems we both like playing with motors. I've built several stroker motors for friends and each time they have been astounded by the torque improvement. These are built for torque, not HP.
Walt, thanks for the kind words. you might be a bit more than 10.5 depending on the gaskets used. which puts both of us into the buying better fuel category.
Which props are you running? I have both B5's and B6's that I run currently depending on what we are doing (cruising or water sports) and which ones need to be re-done.
Walt T
I use 104 octane boost now just so I don't take any chances with detonation. I have total timing around 36 at 3500 rpm which seems to work well.
I have B-5s which were and still are great skiing and tubing props, the low end grunt and on plane time really show up with the stroker. The engine will overwhelm the props pretty easy, it went past 5000 rpm and I decided that was enough so I don't know what top speed is with those. It was 44 mph gps at 4800 rpm with 1.95 ratio on the stock motor. I am in Colorado so I'm dealing with altitude. The stroker went right past that and past 45 and I chickened out. I didn't build it to breathe past 5000. I stuck my F-6s on it and it went to 5300 rpm 53 mph and was still going up but I could see boat wakes coming so I backed off. That's enough of that. Cruising speed is up a few mph with the F-6s on Lake Powell and fuel economy, such as it is, seems about the same but I cant really tell and it's all guessing anyway. Its fun to goose it and you're probably like me, just like the feeling of power when you hit the throttle no matter what you're driving. I do have a pretty good oil leak out the plastic timing cover I guess the O ring type gasket around one of the bolts is damaged. Broken shift cable now so I'm off the water for now. My boat is smaller than your Cruisers but you should get a noticeable increase in low end grunt.
Maclin
Walt, I thought of your stroker install when I read Scott's latest, nice to see you back "over here" again :yo:
Walt T
Nice to be back, Thanks. Miss the old TBM forums. Was glad to see Maclin there
I'm running the stock 615cfm carb from the AQ271 with different jets and metering valve. I am running 93 pump gas and have the timing set at a base of 10 right now. That and a set of B6 props and I'm hitting just shy of an honest 50mph. not bad for my beast of a boat. I need to adjust timing a bit more, I think there are a few more ponies to be freed up.
so F6 props fit on the 290DP?
Maclin
Has to be C6's, probably a typo there.
You are getting some really good numbers Scott, I bet that would surprise someone like me in a smaller boat trying to keep up! I can get past 50mph with B7's but that last 3mph or so takes a few more seconds than I would like. The B5's work well for us as we mostly are loaded and towing, those tap out at 46mph or so.
Good job guys, I am vicariously bench racing alongside... :)
