Vernatherm removal good or bad idea?
Faztbullet
Re: Vernatherm removal good or bad idea?
What I don't understand is if the t-stat is stuck in the closed position doesn't the water sit in the water jacket and boil?
No as t-stats rarely stick shut they mostly stick open....and motor has a check valve or poppet that opens at speed bypassing t-stat that why no pressure build up.
Thermostats do nothing for a carbureted outboard like mine.
The reason you see a lot of ring failures on OMC engines are do to running to cold (bad/removed/stuck open t-stats) and the pressure backed rings. Incomplete combustion from running cold can coke up the ring lands and push rings into a port breaking them.
Thanks so much for all the info. I'm just going to buy a new vernatherm, check valve, gaskets, and replace the two springs just for my own piece of mind.
Joe Reeves
(Thermostat Purpose)
(J. Reeves)
Many engines are considered high performance engines and demand a thermostat(s), and many smaller hp engines also require a thermostat for the following reason. The pistons actually distort/twist off round when running. The thermostat is required to keep the outer wall surrounding the steel cylinder, and the cylinder wall itself at a temperature to compensate for the distortion.
With the thermostat removed, the difference in temperature between the inside the cylinder and the water jacket quickly reaches a point whereas (in effect) you have a oblong piston running up and down a round cylinder, or vice versa. Bottom line is without the thermostat, the piston and cylinder wall could be damaged in a short period of time.
The thermostat in your car isn't there simply to have the heater function properly..... think about it.
schematic
Pistons are actually cam ground (oblong when cold)....they go round when heated.
70% - 90% of engine wear occurs when an engine runs cold during warmup.
just sayin....
Okay... I get it. Lesson learned. This is the very first outboard I've owned that has a thermostat.
