CATransplant
- Feb 26, 2005
- 6,319
Re: Vintage shear pins
Yeah, I thought about the numbered machine screw sizes, too, last night after I logged off. FR says that the originals were monel metal. I have no idea how the strength of monel compares to brass.
I'd save a search on ebay for Olson #2 shear pins. Eventually, someone will put some up there, and you can buy the real thing. Your solution will probably work OK, but if you look at a good hardware store, you can probably find those screws long enough to have a 15/16" unthreaded section or longer. That'd get rid of the threads.
There's always a solution, it seems.
CATransplant thanks for your diligence in tracking this down. I did think about going metric, just didn't consider going outside the states.
Rick - thanks for the tip on Mcmaster. I did a search with them before, but not metric, and there it was all this time.
Yesterday I tried a #8-32 screw cut to length just for testing the motor. Turns out it is a perfect fit, but was not brass. I measure .014" on the #8 and if I remember correctly 9/64 was .013". I did a search yesterday for #8-32 brass threaded rod and was able to order 1 24" piece for under $9 delivered. I realize I'm loosing a bit of strength with the threads, but I'd rather err on the side of caution.
