voids in the transom
Toad64
Re: voids in the transom
I will post pics when i can. Not for sure but i don't remember there being a bow but it only seems to be in just the area where the engine bolts on. Thought that maybe it just worped. I will look back at pics and see if i can tell for sure.
Woodonglass
That is not an issue. If you use a 1/4" toothed trowel to trowel on the PB on both the transom and the skin, and then use the clamps to clamp her down it will be just fine. Clamp just hard enuf to get some squeeze out around the edges and then fillet the squeeze out around the edges. I've seen a lot worse than that and it clamped up fine. Make sure you've got equal pressure on the top and bottom of the clamps
Woodonglass
Looks Good! FYI copy and paste the IMG tag from Photobucket to put the pic directly in your post.
Toad64
Thanx wood and i will try doing that next time.
Toad64
