Re: Voltmeter setup
Every gauge on your console except the speedometer has a +12 volt and ground connection on it that is active only when the key is on. Connect the +12 volt terminal on the voltmeter to the "I" (ignition) terminal on any other gauge. Same for the ground connection. Same for the light. Don't go near the ignition switch.
