Volvo 3.0 firing order
kaimalie
need to find out which is the no.1 cyl ? is it on the water pump side or the fly wheel side. also where does the no. 1 cyl wire go on the dist.
bruceb58
Re: Volvo 3.0 firing order
#1 is near the water pump side. There is no guaranteed location of #1 on the distributor. If you put the engine at TDC with #1 cylinder on its compression stroke, the rotor will be pointing to the #1 location on the distributor.
Kingfam3
does this help you out??
bruceb58
#1 on the distributor can be any post.
fishrdan
.............if someone stabbed the distributor wrong.
It should be like King posted, but who knows what has been done in the past?
bruceb58
Since you can't assume that it is in the original configuration, you have to check.
fishrdan
Why? You can't assume it's not in the original configuration.
Put the plug wires on like they should be and see if it runs,,, 5 minutes max.
If it doesn't run, bucks, backfires, then check to see if the distributor is clocked wrong,,, 30 minutes to 1 hour. You can't yank #1 plug and turn it over with the crank bolt,,, since there isn't a crank bolt. You have to remove all the plugs and turn it over with the alt nut, after tightening the alt belt. A long process for something that is easy on other engines.
kaimalie
Thanks for the replies i'll try it !!! and will let you know.
bruceb58
What is the history of this motor? Was the distributor ever removed?
