- Mar 8, 2009
- 43,222
Put a rag over the shrader valve and press in on the valve to bleed the air out. This might not be the issue because pouring gas in I would think it should have self bleed, but worth a try.
Can you get a noid light to test the injectors? You connect the noid to the connector on the injector and see if its going ON/OFF as it cranks or running.
