Volvo AQ131A starter sparking
scotttu
Well I got my carb rebuilt, well basically took it apart, cleaned it, replaced the accelerator pump and found some blockage on teh arm to the pump....great, so I put it back together and the new "aluminum" banjo washers for the fuel line connector just dont' seem to do the job.<br /><br />Suddenly my starter, which had only turned the engine over for maybe 30 seconds while diagnosing if I had a fuel leak, starts glowing and basically stops.....(yeah, we had a fire, luckily it was fuel and small and I was able to blow it out).....doh.<br /><br />I go out a couple days later it cranks over, twice with no issue (ie 3 seconds) but I look back and there's a spot just above the center of the starter GLOWING...........YIKES! Bet I won't do that again!! I figured because it was so cold out and maybe I had dirty contacts the first time that that was the cause.<br /><br />I bought the boat, the owner had replaced the starter two years ago and rarely, if EVER used it. (The boat sat for 2 years)<br /><br />Could some dirty connection cause this or am I looking at a new starter?<br /><br />I'm going to pull it out and get it tested of course, but anyone heard of this?
Don S
Re: Volvo AQ131A starter sparking
If the connection is dirty, corroded, or loose, that's a no-brainer..... Clean it up, tighten it up and try it again.<br />If you still have the problem (I can't see where it's glowing) then get the starter to a rebuild shop and checked out.<br />Glowing anything in the bilge with a fuel leak is a disaster waiting to happen.
scotttu
Thanks Don, still might not be a bad idea for me to take it down to schucks and get a test run on it......it may have some internal corrosion causing a current spike......<br /><br />That way I can clean the connections proper, I had to do this to the alternator too, it was only showing 13.2 volts........well it still might, we had to put the fire out so I turned the engine off :D <br /><br />I won't be making that mistake ag ain, until I know this starter is in A plus shape i won't be turning it over, but I DID get the fuel leak stopped, some nice juicy brand new copper washers did the trick...
Weirdwalt
Short to ground. Remove the starter and have it repaired before you burn the boat down.
