boaterinsd
- Nov 19, 2010
- 276
OK, so as it goes the water in the oil continues. I have removed and cleaned the Eng oil cooler. Put on new end gaskets and resealed it. Now it still seems to leak. I am trying to figure out the best way to test the cooling system since its NOT( sorry for the typo) a closed system like a car that you can pressure test from the radiator. I was thinking to put a water hose to the intake line near the exhaust manifold near the filter. And I'd remove the filter to see if i have it coming out of the oil filter adapter. If anyone knows a better way to do this please let me know. I haven't pulled the plugs yet to ck for a head gasket problem. Could i also try putting air to the same line/ hose to ck for a leak at the filter adapter or in the Eng oil fill in the valve cover. TIA
