Volvo diagnostic port
pnhigg
I am an idiot but I have a 2006 chaparral 236 with a Volvo 5.7 GI-EF. I am fighting a soft alarm issue and wanted to purchase a diacom diagnostic package but after talking with them none of their adapter cords match what I believe to be the diagnostic port on my engine. What I have is a female connector that is just like what they offer. I have pictured it below along with the ecm and serial and model info.
Is there a different port that I am too stupid to find. The guys at diacom tried but didn’t come with anything that would plug in to anything that I have.
alldodge
You have the correct Rinda connector, you just haven't found the matting one on the motor. It's there somewhere
The square one showing is the CAN buss connector
pnhigg
Both the ones shown in the picture above are part of the boat wiring harness. The roundish plug is the same as the one rinda sells and this won’t plug in as they are both female plugs.
Thank you!
lonewolf41
Mine was attached to the bracket on the ecm. It was on a dummy plug that had to be disconnected to access. It will most likely be within 12 inches of the ecm.
alldodge
Thank you!
That is a new one, like VP messed up the harness and used the wrong connector
alldodge
If it turns out that's the case, and not able to find the right connector to make a jumper. Could get a 8 pin male/female connector, cut both off and connect to new ones.
Either that or make some jumper pins
Fun Times
pnhigg
This is the adapter you bought from Rinda tech?,
Required for 2006 and 2007 model years of Volvo Penta gasoline EFI engines equipped with Volvo’s EGC control system.
These engines are equipped with a 8-pin white diagnostic data link connector.
Please use our Selection Assistant or Contact Us to verify if this adapter is compatible with your engine.
See if this fits my application
I didn’t because it is the same end that the boat harness has. I
i haven’t bought it yet because it is identical to what the boat harness has so that adapter won’t plug into the boat
I will likely just buy that, cut off the end and do the same on the boat and make a connector
I think VP made this harness late on a Friday 😉
Fun Times
Interesting for sure... Has me wondering if maybe @muc might recall a VP service bulletin regarding this situation back around 2006ish.:unsure:
For easier reference, the engine serial number was 4012135891 in the photo above.
muc
"Retired" Association of Marine Technicians...
Yes, very interesting!
S/N, product number and engine designation comes up as an 2003-2005 engine. This would be a MEFI controller. The picture posted shows a EGC controller.
The picture of the DLC connectors show a normal MEFI connector and the scan tool side of a EGC connector.
I seem to remember the round white EGC connector showing up on the last of the MEFI engines, When I asked about it at Volvo school I seem to remember being told it was only for programing at the factory. All this is from 20 year old memories -- so I'm not sure what's going on here.
This engine has never been registered with Volvo. @pnhigg might want to contact Volvo, get it registered in their name and ask about what DLC they recommend.
My best guess is that this is a very early EGC engine and will have a CAN bus DLC connector hiding somewhere on the engine.
Also recommend that if the rest of the wiring harness has corrosion like these two DLC connectors do ---- time to get cleaning on the grounds and power.
pnhigg
Thanks everyone for the effort. I have still been unable to find anything that will plug in to anything on this engine's harness to give me data from the ecm. I am going to take it to a volvo service center tomorrow and see what they say. I have been all over the engine and i cannot find any other connectors. not saying they aren't there, but i can't find them. muc, I agree about the corrosion in the pic i added. I have been over the grounds and other connections to be sure all was well and clean there. This one has me over a barrel. I don't want to...but a holley carb is starting to look appealing.
muc
Hopefully they can help. Try to get it registered in your name. My experience is that service bulletins don't show up unless it's registered.
Please update us with what you find.
Donald0039
Odd things happen. I have a 2011 boat, transom assembly and outdrive but the long block was replaced under warranty with the then current model in 2012. I think most of the FWC was moved from old engine to new engine.
It took a bit of work but I did get mine registered with Volvo Penta.
