Volvo Penta 5.0 GL PWTR - severe overheat - thought I was on fire - troubleshooting Questions
Augoose
Check all connections on the coil and if you get a shocked when putting your hands on the top of the cap replace it & maybe the wires too!
Hey guess what happens when you rush? You make mistakes of course.......so when I put the wiring harness back on after reinstalling the heads, I inadvertently had the harness leads (purple + black) to the coil reversed. The leads from the coil to the distributor were correct.
So looking back, the motor ran for about 10 mins and then wouldn't restart.
Lou C
lol. It happens to us all. Just got done replacing ALL the electronics in my boat and cleaned up the rats nest of wiring under the dash, and in the middle of a 95* heat wave here! Double checked everything & it all works!
Lou C
Let us know how it goes. The true test is taking it up on plane for a while & watching your engine temp & oil pressure and checking for water in the oil…I remember doing that with mine, I was skeptical because it was the first time I ever took apart an engine….. but it all worked out….
