Volvo Penta 5.0 still not starting
LarsonChef
Yesterday I posted that all of a sudden the boat wasn't starting after a big rain storm. It ran perfectly last weekend, and started with no problem on Monday. I recieved a few sugestions... To make sure the distributor cap was dry, a little gas in the carborator and simply to try and let things dry out. I did all of them, and the boat still wont start. Its cranking, but no pop, not even the smallest attempt of a turn. Could it be flooded? Could there be no spark? could it not be getting fuel? I just replaced an $800 fuel pump, so I think its getting fuel, but truly I have no idea? Any sugestions?
LarsonChef
Re: Volvo Penta 5.0 still not starting
Yea, the kill swich is switch is hooked up. I dont know if there is an saftey switch or not. The boat is attempting to start but its not turning over
Joe Larson
What yr is it? I have a 2000 VP 5.0 gl. check the fuse on the top left of the motor
Joe Larson
Also go ahead and pull the lanyard off and hook it back up, sometimes it could have been bumped just alittle
Ayuh,.... Dude,.. You're There,.... You've gotta LOOK....
LarsonChef
Its a 2001 larson 230 LXI. Where is the fuse located? And a lanyard switch, what is that arnd where can I find it? I pulled the spark plugs out and they are covered in gas. I am going to let them dry and change that fuse and hopefully find the lanyard switch. Any other sugestions, Thanks for the help
Don S
What is the FULL model number or the SN of your engine.
Turning over means the starter is spinning the engine round and round.
Starting means the engine runs or in the case of tries to start may mean it tries to start and fires for a bit then dies.
Now what is your problem.
If it is turning over with the start, did you check for spark?????
