- Mar 8, 2009
- 42,940
That's a real bummer, you have water in the cylinders?
If that;s the case, need to pull plugs, disconnect coil electrical connections, disconnect the water hoses going to the exhaust manifolds and crank over the motor to spit the water out. (Disconnect the hoses going to manifolds so you can crank the motor over with water going to pump so not to damage pump.) Then squirt oil in the cylinders and crank a few more times.
Now need to find out where the water is coming from. My first thought is it needs new exhaust
