Volvo Penta 50 hour service?
ThreeMileBayWaker
My 2010 boat has 45hours on it and am coming up to my engine's break in 50 hour service inspection. I've already changed the oil this spring with fresh mineral oil 10w30 and new filter at 30 hours for a piece of mind. Boat is running top notch with no issues ( knock on wood)
What else is required for the inspection? The manual doesn't list anything that needs to be changed. Any help would be appreciated so when I bring it to my dealer I know I won't be getting screwed, not that they have done that to me so far but just so I know whats needed.
Thanks!
Don S
Re: Volvo Penta 50 hour service?
What's the full model number or serial number of your engine? Only way to find info on a 2010 engine.
ThreeMileBayWaker
Volvo Penta 4.3L GL-J ( V6 Gasoline 262 Cu.in.) , SX-A (Ratio 1.79) outdrive. I'm not going to openly toss out my serial number on a public forum, but if you need it I can PM it to you.
Don S
ThreeMileBayWaker
Thanks Don, from the looks of it they are just going to do a quick glance at everything which is pretty much everything I do myself prior to a trip to the lake. I'm hoping now that there is the 4.3L GL-P, SELOC will come out with a repair manual already for the 2007-2010 years so I can avoid the dealer for most things.
