89retta
- Jul 18, 2010
- 780
Here is some info on the trim sender http://forums.iboats.com/attachment.php?attachmentid=98994&stc=1&d=1308598913
I can't promise it's 100% accurate, but here's a link to a shop manual for the 5.0GXi engines (A-F) so it is at least probably similar enough to give you good info.
http://boatinfo.no/lib/volvo/manuals/5057a-f.html#/0
The shop manual for SX-A drive that you saw in the thread above is also on this website. It's difficult to impossible to access on a mobile device however.
The manuals all make replacement look so easy. The real problem in replacing the sensor is getting clear access to the entry and exit point from the stern. From the inside of the boat the exit point is directly behind the steering mechanism and transom plate. The engine is right in the way of where you need to be and then there is that damn clip on the grommet that needs to come off before you can pull the wiring and grommet through. The boat designers did not have ease of replacement in mind when they designed these boats!
