Re: volvo SX drive u-joint and bellows
I believe the spline grooves are in the coupler, correct?
Yep, correct, closely inspect the condition of these splines as well as the ones on the drive shaft. It's kind of hard to see/get in the coupler but clean as much grease as possible off the inside of this by using some long thin tool with a grease rag secured to it. If the splines are ground down (look at the old grease your cleaning off, metal slivers in it?) this could be part of the problem.
I have, however, had trouble getting the alignment tool to go all the way in.
Could be two reasons:
1)Your gimbal bearing is sitting in there cockeyed. It can happen if the drive is removed too forcefully. Measure from the edge of the outer race of the gimbal bearing to the edge of the gimbal bore at the 12, 3, 6, and 9 o'clock positions. Hafta pull the u joint bellows off to do it.
2)Your alignment is off. This could also be part of the problem. I aligned my drive for the 1st time a week ago. Took about 6 hours total just for the alignment; climbed in and out of the boat about 70 times. Once you get it aligned you need to check alignment again with the crankshaft in the 12, 3, 6, and 9 o'clock positions before your aligned properly. Check posts on how to properly align and the sticky Don S posted in the ADULTS ONLY section on this.
Yes, the problem ONLY happens when i increase the throttle to around 2500rpms in gear.
Sometimes problems seem drive related when they're not. At this point I'm just trying to help you decide if this problem is in the engine or the drive so what I would do is: put it back together if your SURE the u-joints, gimbal bearing, flywheel coupler, and alignment are all in proper order, take it to the boat ramp since I'm not sure water pressure from a hose is sufficient to support water flow at that RPM. Rev up the RPM's to 2500 WITHOUT IT IN GEAR and see if you get the same noise. If you don't, put it in gear and cruise around making precise notations of when the sound is reproduced (turns?, WOT or specific RPM?)
