VP SX-M trim cylinder - bleeding method?
baker556
Hi all,
Swapping the power steering pump over and stupidly turned the outdrive whilst hopping out the boat to work on something else, how do you bleed the RAMs? Is it just a case of topping up the power cylinder fluid and turning left to right/up down?
Thanks
steering cylinder is simply turning right and left a dozen times
trim cylinders is simply raising and lowering drive fully about a dozen times
