VRO Failure & Life Expectancy
I still have the original OMS pump on my '98 Johnny 150HPV6. I do carry a gal of 2 cycle oil with me at all times. Should the OMS fail, I can dump the correct amount of oil (or thereabouts) to make a 50::1 fuel mix in the 63Gal fuel tank. I would need to spend some time rocking the boat to mix it, though. It would also be a good idea to d/c the fuel line and pump primer until you see the dye in the 2 cycle oil come thru.
youd need to drain the float bowls as well, because by the time the alarm sounds it would most likely have just raw fuel in them.
Terrapin
The pulse limiter is nothing but a ---" flow fuse " ----To protect the VRO from a high pressure/ airflow event.---It closes in the event of high airflow to the VRO.------The housings on the VRO would explode if subjected to too much pressure.
Can the pulse limiter be permanently damaged by a high pressure / airflow event like a lean sneeze or backfire? Or, does it recover from the event and keep working?
Terrapin
Factory Manual:
1 to 4 Hg with no bubbles.
Bubbles or in excess of 4Hg requires further testing
Cavitation (air) could play a role as well.
I discovered this in my OEM service manual and now understand the test is a little more involved than simply pulling a vacuum with my MityVac. Thanks for pointing this out.
you can make your own little test tool. i made one out of a large syringe.
