Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Ihave a 175 johnson with a 4wire vro which needs to be replaced. can i use a 3wire vro from a 115? if so what do i do about the extra wire which is purple.
I wouldn't.<br /><br />The 4-wire is a VAST improvement over the 3.<br /><br />You're going backwards. If you do not want to buy a new 4-wire. Disconnect the whole thing and run pre-mix.
