VRO V4 90 HP Outboard????year????
northerncockney
could someone please tell me how I can find the year of my outboard VRO V4 90 HP <br /><br />mode/serial E90IVLCTE10270091 This was taken from <br />a freeze plug.<br /><br /> :confused: <br /><br />could you also suggest what spark plugs to use<br /><br />thanks<br /> ;)
Cricket Too
Re: VRO V4 90 HP Outboard????year????
Looks like it is a 1983. Not sure what Champions to use.
northerncockney
mmcpeck....am I correct in saying that the letters depict the year. If so how?<br /> <br /> :confused:
Terry H
There should be a post in the "Engine FAQ" forum that will give you the proper plug choice, and another post that will explain the identification codes used by OMC...just a Thought
rickdb1boat
Champion QL77JC4 or QL82C(Hotter Plug) if you do alot of trolling. Gap at .030 unless trolling alot, then gap at .040. Personally, I've had better luck all around gapping at .040. Better idle and no difference otherwise.
rickdb1boat
Just so you know:<br /><br />E-Evinrude<br />90-HP<br />I-FICHT Fuel Injection<br />V- Special Gearcase <br />L-Long shaft<br />CT-1983 Model<br />E-Electric Start or model run
Cricket Too
Am I missing something, how can it be a Ficht if it is a 1983? I'm a little confused.
rickdb1boat
Let me double check the numbers again.
rickdb1boat
mmcpeck, you are right.(Brain freeze) Ficht did not come out until 95'. Huuumm!<br /><br />Unless he misread a letter. Double check the numbers northerncockney! Could be a "T".<br /><br />Got them from modelguide:<br /><br /> web page
northerncockney
An I or a T I really don't mind guys.<br />Hey you have all answered my question and then some.<br /><br />Thanks to you all<br /><br />Northerncockey...United Kingdom ;)
