Re: VST Tank Issues caused by heat from Engine?
you still simply dont get it.
the feed pump,due to a 10 PSI check valve, feeds fuel to the VST at 10 PSI minimum.
more than enough to balance out anything.
most likly the fuel lines are contaminated.
see that quite a bit.
I maintain over 50 of these F225/F200 and own an F150.
all get E fuels none have problems.
however when it happens I replace ALL the fuel lines.
let a section of your line dry overnight then inspect it with a flash light.
any white or yellowish deposits mean the line is contaminated and a repeat failure is assured.
the VST vent is a check valve as well.
keeps the system mostly nuetral and aids in vapor control.
will allow air in and out but try to nlow through it.
its that shiney metal thing that goes into the air box on the upper port side.
your deer dog is hunting rabbits not deer.
