W.O.T. Bog questions
Fishingaddict88
With a WOT bog, is that a symptom of fuel too rich or lean? No backfire or anything just bogs, although I didn't run it very long at WOT with the bog issue. Everything I've been reading it seems that it's a symptom of being too lean, yet all the signs point to me have a rich fuel issue. Black plugs, gas in oil...
Just trying to narrow down my issue here. I have an 1988 130hp 3.0 4cyl w/ a Mercarb
I checked fuel pump and diaphram, looks great. It did have the old rock filter in it, replaced that with a new quicksilver paper filter (aren't rock filters non existing nowdays?) Did not do a pressure test. Fuel pump looks pretty new, most likely was recently replaced. (Note: I have not ran the boat yet since changing the filter to see if it made any difference.)
Even though the carb seems to have been recently rebuilt and pretty clean looking I plan to replace the jets, float, and I'll try the spring loaded needle (I've read that helps with rich conditions)
Just not too sure what's going on here, any thoughts would be appreciated.
Rick Stephens
Rebuild the carburetor. Since the plugs look wet then your engine could be bogging from too much fuel. Air fuel mixtures have to be within a fairly narrow range to produce power, too high or two low ratio will bog. I've never seen the need to replace jets. Get them clean and they should be fine. I can't think of much other than corrosion that can ruin them.
If the problem persists then hooking up a fuel pressure gauge would be next step.
alldodge
Carb work might help but unless testing is done were throwing darts at a board
